My p800 don't open message and always show opening message in first screen of Message
Help Me??? (Message Problem)
I didn't quite get it:
Do you mean that you can't view messages because there's one that is always open and you can't close? :con?
If you really can't close the message by software, try to start up the phone pushing 10s long the on/off button.
If this won't do... well I only see the worst solution: reset the phone! Watch out because you have to make a backup in the PC first and update later or you'll loose for good all the data (messages, contacts, aplications, etc) on the phone.
