new screen
6 replies · 1,637 views · Started 24 October 2004
hey ppl, i jus wanted 2 know if i can put a new screen in my ngage... but, id prefer it to be the screen which is fixed in the nokia 6600...is that possible...will it gimme problems... plz help...will it work properly...
You have to replace the N-Gage's display with an N-Gage display (spare part). A 6600 display will not work (the N-Gage's version of Symbian/Series 60 does not have support for more than 4096 colour displays).
N/A wrote:You have to replace the N-Gage's display with an N-Gage display (spare part). A 6600 display will not work (the N-Gage's version of Symbian/Series 60 does not have support for more than 4096 colour displays).
no my screen is not damaged... i just wanted to upgrade it...so can i increase the brightness.. orr can i put the ngage qd screen which is more brighter...???
You need to check what firmware version you have. Type : *#0000# into your phone and it'll return what version you have. If you're running 4.00 then you'll need to get the phone re-flashed by Nokia to 4.10 because that older firmware has a dimmer screen than the newer one. Otherwise, the Ngage screeen should be as bright as the 6600.
neuro wrote:You need to check what firmware version you have. Type : *#0000# into your phone and it'll return what version you have. If you're running 4.00 then you'll need to get the phone re-flashed by Nokia to 4.10 because that older firmware has a dimmer screen than the newer one. Otherwise, the Ngage screeen should be as bright as the 6600.
and what about the ngage qd screen can i get it fixed?? :redface:
Yep, take it to a Nokia service center (apparently a lot of folks live around these areas but I never seen any around my area) or send it to Nokia and have them re-flash it for a small fee. Go to the nokia website for more info.
If you put a 6600 screen, you will still get 4096 colors, but since it is a tft screen you will get more clarity right? can anyone tell me what happens when you put a 6600 screen on n-gage? the screen will work at 4096 colors right? 3660 also runs on S60 V6.1 and it has 65k support. so the software has support for 65k screen, only n-gage does not have it.
