K im totally new to the p800 bought one on amazon and waiting for it to arrive
just a few questions
i have a load of ngage apps and was wondering if any of them would work on p800 bemused in paticular
is there any good sites where you can get loads of p800 apps and i mean cracked ones not one you have to pay for
will memory stick pro duo work in it if you have a memory stick duo adapter cause i just bought a 512mb card
If you're looking for craked software that you don't have to pay for others work you came to the WRONG FORUM. :icon13:
On the other hand if you're talking about FREEWARE take a look at the article published here in AAS: :icon14:
http://www.allaboutsymbian.com/news.php?id=29308
I'm sure you'll find very good aplications. 😊
Ngage apps won't work
Warez are not allowed (and therefore, thread closed)
MS Duo PRO cards won't work, only MS Duo (up to 128MB)
