Seeking for Help ..
2 replies · 1,111 views · Started 24 October 2004
I'm new to the Symbian C++ development ..
I have installed C++ Builder 6 with C++Builder_Mobile_Edition_1.2 ...
When I compile a default basic HelloWorld Mobile application, I got this error :
________________________
+ SDK: Series 60 SDK 1.2 for Symbian OS
+ Project: C:\Symbian\Series60_1_2_B\series60ex\Project\Project_Sources.bpr
+ Target : \Symbian\Series60_1_2_B\epoc32\release\winsb\udeb\z\system\apps\Project\Project.app
+ Current Directory : C:\Symbian\Series60_1_2_B\series60ex\Project\
+ Command: cmd /c perl -S abldb.pl make winsb udeb
+ 'perl' is not recognized as an internal or external command,
+ operable program or batch file.
+ Read buffered data.
+ 0 lines of buffered data.
+ Project Build failed.
Given that I have installed ActivePerl on my PC, and I have added perl in the Environment Varaibles ..
How can I solve this problem ??
If you open a command window, what does the command "perl -v" display (version 5.8.1. binary build 807 works for me)?
Is the c:\perl\bin directory (or where ever you installed Perl) in the PATH?
N/A wrote:If you open a command window, what does the command "perl -v" display (version 5.8.1. binary build 807 works for me)?
It displays :
This is perl, v5.8.4 built for MSWin32-x86-multi-thread
(with 3 registered patches, see perl -V for more detail)
The PATH I have in my environment variables is :
C:\Program Files\Common Files\SYMBIAN\Tools;C:\Symbian\Series60_1_2_B\epoc32\tools;C:\Symbian\Series60_1_2_B\epoc32\gcc\bin;c:\Perl\bin;C:\PROGRA~1\Borland\CBUILD~1\Bin;C:\PROGRA~1\Borland\CBUILD~1\Projects\Bpl;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Program Files\Common Files\Autodesk Shared\;C:\Program Files\backburner 2\;C:\Nokia\Tools\Nokia_Developers_Suite_for_J2ME_2_2\bin;
