Purchased Nokia 6620 ...want to install new ringtones, wallpaper, etc from my "locker" at "www.3gupload.com" however, I'm a Mac user and software that came with my Nokia 6620 apparently supports PC users only. Any fix? Thank's!!!
Nokia 6620 CD for Macs Users Available
No "fix", but try the latest Apple iSync instead (might require an OSX upgrade, too, however).
the latest version of isync works a treat with the 6600 and should do for the 6620, free from th eapple site.
transferring files over though, do you have bluetooth? if so just use the Bluetooth file Exchange util and install Forward on your phone (free) to move them out of your inbox. it's what i do with my powerbook and it's simple and easy.
marilynsaddress wrote:Purchased Nokia 6620 ...want to install new ringtones, wallpaper, etc from my "locker" at "www.3gupload.com" however, I'm a Mac user and software that came with my Nokia 6620 apparently supports PC users only. Any fix? Thank's!!!
You can use the "send file" command from the Bluetooth menu to get files to the phone. I do it all the time sending applications, pictures, tones, etc.
The 6620 does not work with OSX and iSync. It will take an update to iSync for this to happen. The 6600 is supported, but the 6620 has changes that prevent iSync from working. I have been forced to sync with my PC, until this is fixed.
- Keith
