Hi, I bought a Tinlex USB Bluetooth Dongle. I have no problems using PC Suite to connect my 3PCs (1 desktop, 1 laptop @ Home, and 1 desktop @ Office) with my 6600.
However, using the Bluetooth applications themselves is a problem on my laptop. For my 2 desktops (at home and at office), the "Bluetooth Icon" on the system tray is "able" (on white color by default, and on green color if I "pair" the 6600 with it), and I can use its applications like headset, audio gateway, "My Bluetooth Places", etc.
But for my laptop, the Bluetooth Icon is always in "red", means "Bluetooth Disable" (according to the guide). And I can't never use any of the standard bluetooth applications which I can use on other desktops (the like "My Bluetooth Places", "headset", "audio gateway"😉, it always prompt me "Bluetooth device not found"/
I check on the "Device Manager" and found that for my 2 desktops, there is only 1 device under "Bluetooth Radios", it is "Cambridge Silicon Radio Ltd. Bluetooth Adapter", its location is at "Location 0 (USB Device)". However, on my laptop, there is another device under "Bluetooth Radios", it is "Microsoft Bluetooth Enumerator", and its location is "on Cambridge Silicon Radio Ltd. Bluetooth Adapter". At first, I thought the "Microsoft Bluetooth Enumerator" ride on the CSR and interfere with its applications ("headset", "audio gateway", "my bluetooth places"😉. So I disable that device (Microsoft Bluetooth Enumerator), but it doesn't work either.
So, please tell me what went wrong here ... Btw, I'm using 6600, all my OS is WinXP Pro, SP1. Thanks for your reading and helps ...
