Hi All,
I'm facing two problems
1) Calendar entries not getting saved
Calender --> date --> meeting --> {enter something & make alarm on} --> done
When I exit Calendar & again open it, it doesn't show any entries against that date. It means it's not saving the entries. What could be the reason?
2) Calendar setting is not getting saved
Calendar --> setting --> default view --> {Select month view}
When I exit Calendar & again open it, default view is day view. When I go to setting, it shows default setting. ie default view - day view, week starts on - monday etc etc.. What could be the problem?
TIA
Mahesh Kokadwar.
koks wrote:Hi All,I'm facing two problems
TIA
Mahesh Kokadwar.
The same thing happened to me after installing Stacker version 3.00 As soon as I removed the app, and restarted my phone (Nokia 6600), the Calendar behaved as expected. According to SymbianWare, Stacker should not be the cause of this, since it it doesn't have any always-in-memory modules. So, it might not even be Stacker 😊
Regards,
Any Mophun engine based games on your phone (if they don't have yet fixed their runtime problem of clearing the Calendar, then perhaps that's the reason)?
Spy call is another reason for this problem
