Midi player
7 replies · 2,357 views · Started 25 October 2004
Maybe it sounds a little strange but does anyone know about a midi player which allows playlists?I mean, continuous playing of a number of files. maybe there's an MP3 player that play also midis?
Hi ClozeOne,
it's not really strage, It's niceto here midi's on your phone, I do 😊
AnyWay I think that "MultiMedia Player" is what U need .
it doesn't play Mp3's but it does play midi's playlist.
found it! Ive got a bit of a problem now, though. Im supposed to register and in psilocs webpage multimedia player doesnt appear, so I cant get the register code. Could you (the one who answered before) give me some advice? write to my email if possible: [email][email protected][/email].
Thanks a lot!
Don't worry, it does not work anyway. thanks all the same! Does anyone know about another similar program?
Tuba wrote:Hiya, I know that VanBasco does the trick (check www.google.com ---> searchmachine) otherwise check http://download.dweilorkest.com
there's a midi-karaoke player with playlist, its in dutch but its great i think
I might once make it multilanguage support if there's interest in it.....
Greetingzzzzzz
Tuba ([email protected])
Hi, Tuba... I've been in the site U said,
I only see PC programs, where is the S60 ones ?
