Log time half an hour behind
3 replies · 1,959 views · Started 25 October 2004
Wirelessly posted (Nokia3650/1.0 SymbianOS/6.1 Series60/1.2 Profile/MIDP-1.0 Configuration/CLDC-1.0)
my log shows calls/messages/gprs connections half an hour behind than the actual time. I searched the Forum, but only found a solution for nokia 6600 and 7610. Turning off automatic time update and even hard resetting does not help.Does anyone have a solution?Rohit
Strange. . . After hard resetting the phone for the 2nd time,and restoring the backup made on mem. Card and not setting the time properly(it automatically came 12:00am, i just clicked ok), then rebooting the phone, then putting the automatic time update and then rebooting again then entering the correct time has put the log time back in order. Very confusing process, but now the log works properly.
Rohit
Well. my 3650 also showing same problem. i tried to make OF autoupdate time. but still same.
