Delete my contacts
6 replies · 2,214 views · Started 25 October 2004
Hell All,
Can anyone tell me how to COMPLETELY WIPE OUT all my contacts?
I did a test synchronization with my PC and now have loads of crap data.
I don't want to do it manually (one by one...)
Cheers,
CombatSheep
CombatSheep wrote:Hell All,
Cheers,
CombatSheep
I dont know if theres an easy way of doing this but a full format or manual delete. Try going to c: systems/data/contacts.cdb i think thats the contacts file there but i dont know if u can delete it when its in use... :frown:
And just in case it is needed for the Calendar, too:
menu -> Calendar
Options -> Month view (in case it isn't already)
Options -> Delete entry -> All entries
Thanks guys! I feel silly... It was easy, well once I learned my way around the menus. For the most part it's very intuitive but sometimes...
u cant do modification wid contacts.cdb...no deleting neither overriding...fexplorer does not allow u 2 do tht!
