What about headphones?
6 replies · 1,826 views · Started 26 October 2004
Hi
As you know, the mini plug in the Sendo X is propietary (I think 😊)
Does someone know a way to place other headphones or if it�s possible to buy a new Sendo one?
CU
morph wrote:Hi
CU
the only thing I can confirm you is that the headphones that come with sendo you can buy them in a spare part.
check expansys for example.
morph wrote:Xerxes.... the adaptor at expansys... If you have the phone in the pocket, do you must to take it out to be able to touch the call button?, I say this due to the short distance between the connector and the microphone.
Yes. That is the downside, but I think it's worth it to be able to use decent headphones.
