I'm doing my first theme and now I can't get any further.
I have struggled several hours trying to find out where the problem is but no.
I have done every part in the Theme Studio and now I'm trying to create that theme.
All I get is a theme creation failed. See report.
Well, I have checked one by one all the categories and the problem seems to be in section This and that. More specific in the Navigation Indicators because the report says:
Bitmap file 55 : /c16qgn_indi_submenu.bmp
Bitmap file 56 : /1qgn_indi_submenu_mask.bmp
Bitmap file 57 : /1qgn_indi_scroll_down_mask.bmp
Bitmap file 58 : /1qgn_indi_scroll_up_mask.bmp
Out of memory.
FAILED while executing bmconv. Check if any of the picture is 16 bit type or having alpha channel.
I have tryed to do everything with those arrows. Make my own or use the default. Read the help file and quide pdf. Problem not solved. My arrows are black and white like they should be. Also tryed different kinds of Coulous gradients and nothing.
Anyone got a clue what I'm doing wrong or what the problem might be?
Thanx!
