Is there any way of password protecting or hiding certain folders on the 7610. I have seen software to do this but wondered if there was an easier way ?
Password protecting folders
what do u mean by an easier way? u can encrypt files by using SMARTCRYPT or also compress them using zipman and then set a password when someone tries to decompress them. u can get those software easily.. search www.my-symbian.com and www.wildpalm.co.uk
Wht i am using is Sele Q Allthough it not fully compatible with 7610 but it will do wht u want
Just install it and create a new folder in MMc and move pictures, Video etc and u can use it in property in Sele Q and "On" the Option of Hidden
and the folder will be only visible with File manger (Not inbuilt) rest it won't be visble.
OK thanks folks. I've got SeleQ somewhere as I had it on my 3650.
