I am currently using the X's sync functionality to sync with Outlook when I'm at work. It's great because I now have access to everything in my calendar where ever I am.
However, I always have to sync manually - I can set the sync automatically thing in the Sendo Connectivity app, but I still need to keep the app open, and you also need to click continue after it has done a sync. What I really want is something that runs in the background, then just syncs whenever it gets a connection - this way if I connect via bluetooth I just need to go near my computer & I'm sync'd! 😊
Anyone know how I can do this? I was thinking of trying to write some app which opened the sendo app in the background (hidden) and kept trying to press continue (although this may cause problems if I actually want to run the sendo app itself). I imagine there may be a COM object or something I could use to do the sync which would be better - anyone have any idea about any of this?
Thanks!
jpg
