how can i use the bluetooth on my p910i to connect to my pc to use my dsl ?
as far as i know this is called reveres connection sony eric themselfs aint even hurd of this action but i know u can do it on some nokia's
thanks people
thanks people
Other than the usual question of "why would you want to?", there are guides on here. If you do a quick search you should come up with a detailed, step by step run through (might even be in one of the stickies at the top).
But basically, you create a dummy account in your P910i with no settings, set it as default, establish a bluetooth connection with the PC and open up Opera. It should see that there are no settings, realise there is a bluetooth connection open and use that.
all i did was download opera p910i and connected the phone via serial bt connection then opened opera and it worked 1st time bit of luck
my reason i want to is we only have 1 pc and its allways being used so this is another way for me to access the net hope this will help other that may have wanted to do this
