Problem
1 replies · 1,035 views · Started 27 October 2004
Hi!
I buyed Siemens SX1 phone, but noticed recently that it only has firmware 6. I downloaded firmware 12 from the siemens web page. In insturction on web page, was wrote that joystick should be pressed down while turning on the phone, so the phone would go to update mode. Well it didn't.
Windows detects siemens thru USB port fine, and everything works fine, but still, the firmware updation program cannot find the phone(I tryed to update, even update mode didn't succeed)!! Could you help, what should I try next ? I did download right version of firmware to my phone, no problem there. !?!?
Now to the other strange thing. I can send .AMR and pictures fine with MMS function, but not .MID. Phone just tells that file is corrupted or unknown (and it is not). Is sending .MID thru MMS forbidden with this phone ? strange..
- Dracone
No need to answer the first question (FW). Problem solved.
And I found that there were writing about MMS problem on forum. So, forget this =)
