9210 dead not powering on just top light blinking cant even charge
2 replies · 2,877 views · Started 28 October 2004
Hi fwends, i am fom Sri lanka, my 9210 was in swedish lang. So i try to convert it to English but i cudnt cus no technology was here. anywaz i remove it and i disable its inside small battery.
then i fixed it but it was not working after that just top side light blinking cant even charge it. then i gave to intall fresh S/W but whn its instaling its geting stuck and same old prob comoning.
Plez who can help me to fix my phone. In Sri lanka theres a no nokia service station. plez plez help me what i have to do can it be power problem but i double check inside the phone every thing in order as it was.
plez plez fwends help me im in suffer cus of my dead 9210.!!!
you mean you removed the small battery behind the keyboard in order to change the language to english? you couldn't have! because the language is installed from the firmware.. besides! it is not a battery! its a capacitor which stores time and some other settings for your communicator..
usually, if your front side blinks and your pda side won't boot, you can easily plug your charger into 9210, take your 9210's battery off, place it back, unplug your charger then it should start again.. IF NOT: YOU BETTER KNOW WHAT YOU'RE DOING WRONG WHEN YOU DISASSEMBLE YOUR 9210..
Hi, DraKkenKreIg
Thkx for ur valuble information, i tryed the way u told me.but still de same. now blinking is not there any more. dont kno what happend.now its totaly dead. plez tell DraKkenKreIg there s no place to send this phone in sri lanka So i have to get it done this. my fwend told me even he wornt ablet to flash it cus of this problem it not powering on!!!
I am waiting for solution
