Hi can someone help ever since i installed sp2 on windows xp pc suite will not connect, after a lot of playing around with some of the settings i decided to uninstall pc suite & then reinstall it & then it worked fine.
However the next time i reboot my computer guess what pc suite dosen't work again & i have to uninstall / reinstall & then it works fine again untill of course the next time i reboot, So far i have worked out that the problem is with the mrouter by the way i also have mrouter beta 3 installed & i have noticed that when i remove pc suite & mrouter that comes with pc suite that my bluetooth & mrouter beta 3 connect straight away is there any way that i can remove the mrouter that comes with pc suite so that i can just use mrouter 3 beta has anyone else had this problem please help Thanks in advance
SAL45
pc suite
Try looking at previous threads, like this one:-
http://www.allaboutsymbian.com/forum//forum/thread/27420/
