I wanted to send some screenshots of the GUI of the Sendo X to a friend
on his 6600.
Then I discovered, I cannot insert more than 1 picture in an MMS on the Sendo X!!
What's up with this?? On the 6600 I could make a "slide-show" in an MMS
with several slides/pictures in an MMS, and even with a separate sound
file to each slide...
So if I now want to send 4-5 pictures in an MMS, I actually have to send 4-5
MMS messages!!! (with the corresponfing costs)
This is ridicilous and should be fixed in the upcoming firmware!!! ASAP!!!
Now I also discovered that it is not possible to edit an MMS message when you forward it, like I did on the N6600...
Weird, anybody succeeded in doing this?
sorry messus,
i must say i've never sent mms. Strange maybe but true, they ask 50 eurocent for it here and i wouldn't know if anybody could receive it.
When this does occur, i will keep you updated.
anybody here hasn't to do with MMS messages? help messus out here 😊
The 6600 is based on Series 60 version 2.0 and Symbian OS 7.0s. The Sendo X is based on Series 60 version 1.2s and Symbian OS 6.1. What features you're missing on the Sendo X are probably explained by this; i.e., the 6600 is based on newer software with more, new features.
