First off i searched the forum and did a google search on the question and the only answer i got was deleting the system.ini file which did not work!
When i run roms on picodrive emulator namely Evander Holifield Boxing when i go into a match before a fight starts it says app closed main! I can not even load up Shining Force II past the intro sega screen without it starting an error "App Closed Main!"
Please help i need to play Shining Force II!!!!
*#7370#....reinstall everything again as it has fukked up ur shred memory don let it happen other wise ur fon vl b no more in use...app closed main is d most freaking thingy in symbian OS....hope u can understand value of ur fon...
7370 does not fix this problem as I found out the hard way-all my configs have gone.
mebbe..me not tht much in2 games.sorry
i get the same message once every 2 weeks.........is it something to worry about or not
iv been searching the forums and there were other mentions of app. closed MAIN, but those topics said that its because of Pilosc (or something like that) apps but i don't even have any of those
App.Closed.Main or whatever is just an indication that the program in question has crashed. The issue here is that PicoDrive is still in alpha/beta state and does not fully support all games. Naturally, one would assume that there is some feature that Shining Force II (or your boxing game, etc.) that is not supported, and PicoDrive crashes.
This is normal. Wait for a new version of PicoDrive, which will be released whenever fdave has time to work on it.
A bit off topic, but can anyone tell me how much time is needed for the format (*#7370#....) ??
I've tired it twice and it just shows "nokia" for an hour, and then scrwed the device .... Should it take more then a few minuts ?
