😃 can someone please tell me how to set up internet on my 7650.i am on o2 with free wap.also what things can i watch on programs such as realplayer.thanks in advance.
please help
Internet as in HTML?, for this you will need to install webviewer. You cannot to my knowledge access HTML(WWW) documents through WAP. You will need GPRS web, which you can get from O2 but you won't get it for free. You can either go on a Pay as you go, or buy MB's.
As for Real Player try their website www.real.com and there should be some links on there.
you must use webviewer (I have it) it's the only way to acces the internet - I use it with a 'normal' connection i.e. without gprs. the 7650 has no html browser.
can you please tell me where to get this program.and explain a bit more about the 'normal connection' you use.thanks
All you need is the Password and the username of your ISP! You are on the net right now aren't you?
So use the same details and create an accesspoint with your ISP name, dialup number, set the type to analogue, username and password! use this accesspoint whenever you want to use the web! Hope that helps! If not there is plenty of info on other threads, make a search and you will find a lot of info!
Bye
Ah and if you live in the UK, go to www.nokia.co.uk and configure your phone there! very easy to do!
You can webviewer from any serious site that has j2me apps
hope that helps
here, you can find the webviewer :
http://reqwireless.com
Domi.
