i just recently noticed that on "Log" (shift-ctrl-L at Desk) -- my data connections arent logged. Specifically using 9210 as a fax modem.
is there something wrong?
There might be, because in my log the data-calls are logged. Are you sure you are not using the 'filter by type' function?
NTOO
thanks, i will check on it. but i presume i didn't use any filters. 😉
