help me please, my nokia 3650 got wet.... any advice from you guys? thanks :redface:
MY 3650 got wet!!!
Just Remove the Pannel and put in a cloth and put in sunlight but beware that the screen should not face direct sunlight cover it with cloth and put upside down screen.
I have done this with my 7650 and it was 60% alright but i personally can't recomend if u want to do then u take the risk.
THE SIMPLE WAY IS TO VISIT NOKIA CARE CENTER THEY CAN FIND OUT WHT PROBLEM IT HAVE WHICH PART IS DAMAGE AND WHICH IS NOT.
