Personal Hands Free reliability
4 replies · 3,021 views · Started 10 October 2002
I use my 9210s personal handsfree vertually all the time and am now on my second one. Both have developed a fault which means that when moving, eg talking while walking with the 9210 in its holder, the phone keeps thinging the hands free has been connected then disconnected and connected and ....... The hands free continied to work as a microphone and ear piece but the button stops working and you get a stream of irritating beeps interupting the call.
Before I complain to my retailer again has anyone else had similar problems with this unit - or the one for th 9110 (the current replacement unit I have is for a 9110)
[quote="Guest"]I use my 9210s personal handsfree vertually all the time and am now on my second one. Both have developed a fault which means that when moving, eg talking while walking with the 9210 in its holder, the phone keeps thinging the hands free has been connected then disconnected and connected and ....... The hands free continied to work as a microphone and ear piece but the button stops working and you get a stream of irritating beeps interupting the call.
Thanks[/quote]
I got my 9210 at the start of the year, and I plug in the handsfree every time I get into my car. So far, no problems. yet...
I assume the problem is on the connector end? Maybe you could open it up and check the solder joints?
And I don't know how you use the 9110 handsfree....the damn thing always had a habit of popping out when you apply even the slightest sideways pressure to it...
I think the problem is using the 9110 one. I have the exact same problems when using my old 9110 one, but no problem if I use the 9210 one.
Three days ago I swaped out my hands free headset for a similar reason. Mine would disconnect standing still. The other party could hear me (through unit's microphone I suppose) but I could not hear them through the haands free headset. CompUSA here in TX swapped it out without a question. Now it works fine. Trya another headset.
I have the same problem. I listen to WavGo almost every night using the handsfree. I exprienced that when I moved the phone or the wire, it disconnects. The handsfree is very sensitive. I suggest we all take good care of it. 😃
