I have a Nokia 6600, and I am problems syncing my contacts from powerbook using iSync. I get the following error message:
"Phone is low on memory. Please remove some data from the device and sync again."
But I have no idea how to 1) check the available RAM 2) add more Ram. Can someone please help me!
vgoklani wrote:Hi, I have a Nokia 6600, and I am problems syncing my contacts from powerbook using iSync. I get the following error message:
OK you must have everything/most stuff stored on the phone memory rather than the card.
Press your blue menu key, press options, page down to memory and select phone memory and it will display a list and memory used for each item. From here you can determine what you can delete or perhaps move to memory card.
Sound, video, image files and installed applications tend to take up the vast majority of memory.
