i use fexplorer n befor formating/reseting my fon i took bakup of my contacts.cdb on e drive ...i again installed everything on my fon again ..but now me not able 2 overwrite tht contacts.cdb...its like im loosing all my contacts....plz help me...is there ne process 2 read it in txt mode or something...ths is d single problem i ever had faced wid my fon...plz help!SOS!
how 2 overwrite contacts.cdb?
Use Psiloc Extended File Manager: http://www.psiloc.com/index.html?id=159
same prob wid me....just temme w8 is d process like.....i have dloaded n installed it...but i cudnt find d system:data folder 2 replace ths file....plz help.....rgds...i can copy it but cudnt find tht destination folder...
N/A wrote:Use Psiloc Extended File Manager: http://www.psiloc.com/index.html?id=159
Hey N/A,
i haven't tried Psiloc Extended File Manager myself, but i'm curious on how much difference it would make because the problem Fexplorer's experiencing is that contacts.cdb is already in use, so u can't delete it, overwrite it nor rename it.
I recently upgraded the firmware of my QD so my contacts went down the drain. Thankfully i made a backup of my contacts.cdb onto my MMC card, but it never occurred to me i couldn't copy it back in (DOH! 😡 ).
The PC Suite that came with the QD doesn't help me becoz:
1. my bluetooth dongle went kapoot so i have to go get a new one
2. i don't use any of the Email clients compatible with PC Suite so it has trouble sync'ing.
Any idea on how to copy my contacts back into the phone (preferably without using PC Suite)?
The quick way to do it is as follows -
1) make sure the contacts.cdb is in drive E
2) open Fexplorer, keep it running in the background
3) go to menu->extras->memory->backup phone memory
4) quickly, while the phone is perfoming the backup, press and hold the menu button and go to fexplorer, copy contacts.cdb from E drive, and go quickly to c:\system\data, and paste the file. it will say "file exists overrides?", say yes.
5) the contacts.cdb file is replaced, BUT you have to make sure the memory was being backed up at the same time.
DO AT YOUR OWN RISK!
for details, refer to the sticky thread in the nokia 6630/6680/6681/6682 forum.
rohitkhannak wrote:The quick way to do it is as follows -
WOW, sounds risky! haha...
Checked up the post, thanks rohitkhannak!
For other people reading this post and have the same problem here's the post at that forum.
http://www.allaboutsymbian.com/forum//forum/thread/31803/
