I just buy 6260 from shop yesterday.
Morning I found problem of software Messaging. When I will create MMS aand insert object > image/video clip. I cann''t do it. It show " App.closed MCE" and then trminated. I don't know why? What should I do ?
Evening I check with NK care center in my country. I have some suggest that must restore mobile. After that, it like feel good :icon14: but 2 hours later this error came back . I check other software "Web". When it connect to Provider Server. 6260 Alert this " App.closed ....." and terminated. 😮
I didn't know this occur from 6260 or Symbian Software.
Pls suggest or Advice too.
Thank U. 😊
If u realy formated the phone as well, and the errors still exists, then it looks like a bad flashed Firmware.
U put in standby screen *#7370# followed by the securitycode?
and there is no 3.party SW installed?
then go to your store and return it.
they shout give u a new one.
Last night. I search with this topic. Have many problem like me but in N-gage case.And I found that I have one program(3 party) about local input (not native Eng.). I think it cann't support, so I stop that program and restart then again.
😊 All problem Clear !!! 🙄
Thank for ur suggest. It absolutely true.
😉 nice 2 hear...
and dont worry: take a look my bad english:
ure not allone.... :hmmmm:
always go 4 shure, that the Programs are compatibel with the Phone.
Serie 60 devices are not all the same:
some programs that work with a 6600,
maybe crash in a 6260.
But time will passing by and then the most Programs will work like a charm. :angel:
