Hello,
i downloaded mp3go and it worked fine....i transfered a mp3 file from my computer to my nokia 3660 but it couldn't open the file when it went to inbox(i expected that). i couldn't move it anywhere outside of the inbox except to my messages. When i went to open it in mp3go i couldn't find the file. Can someone tell me the file extention to find files in an inbox...or another way to get it to work?
thank you
MP3go Finding Files
Liquid.Methane wrote:Hello,
thank you
You need to use FExplorer or any other file manager.
You could download the FExplorer app from www.gosymbian.com. I would recommend FExplorer for it is a freeware, highly useful app.
you need to go to either C (if the file in messaging is in the phone memory) or E (if the file in messaging is in the memory card), then go to System folder, then to Mail folder. Keep on looking around this area (C:\System\Mail or E:\System\Mail) for the MP3 file, you should be able to find it.
once you've found it, cut/copy it to another location, using the file manager's built in options. then finally paste it somewhere else.
then use mp3go to find your mp3 file.
rohit
