Pls help: recommend MP3 edit software
1 replies · 2,173 views · Started 03 November 2004
Hi
Could someone out there please recommend a decent software programme that i can use to 'cut' some MP3s and then convert them to mono for ringtone purposes.
I would be very grateful, cheers
p.s freeware or pay programmes
deluxe99 wrote:Hi
do a google search for Audacity. it's free and works really good. oh, and you must download "LameLib" plugin so you can export the file as mp3. if you want your mp3 ring tone loud, increase the db.
