Can someone please help????
1 replies · 881 views · Started 03 November 2004
Hi this is my first post. I got a nokia 7610 a couple of weeks ago after upgrading from the SE k700i. I have a couple of problems.
1- Is there anyway to connect my phone using the cable that came with it and nokia software. I have Windows ME and wont allow me to use it. Is there another version i can use.
2- I have been given a cd with themes, ringtones and movies. How can i transfer them to my phone. I bought i Bluetooth dongle thing and tried it but when i send it there is a message saying out of memory. It tries to send it to my phones memory but can i change it to the RSMMS.
Also this is just a question about bluetooth. I installed the software i got with it. Widcomm bluetooth software. It installs fine and works but then stop my internet from working. I heard its something to do with sharing networks so i need to stop the bluetooth one but dont know how. I have Windows ME and AOL.
Thanks in advance.
Alan
Unfortunately the Nokia PC Suite (latest is 6.4) requires Windows 2000 or Windows XP, and there is no fix for that (except if you upgrade your PC's operating system),
You can in the "Messaging" app (Options -> Settings -> Other) change the "Memory in use" from "Phone memory" to "Memory card". It will move your Inbox from phone memory to the RS-MMC card (with presumably more room).
Even if you don't do that, you can send smaller items (that do not fill up the phone memory) one by one, then open them from the Inbox, and if they're .sis or .jar files, they get installed after which you can delete them from the Inbox to make room for more.
Same with ringtones, images, etc.. Open them from the Inbox and save them elsewhere.
