ringtone volume on 7610
2 replies · 2,055 views · Started 03 November 2004
hiya guys, is there anyways of making the ringtone volume higher on a nokia 7610, cause i just got mine and turned it all the way up and its not very loud, so wondered if a way to turn it up more.
thanx
conty
cOnTaGoUs wrote:hiya guys, is there anyways of making the ringtone volume higher on a nokia 7610, cause i just got mine and turned it all the way up and its not very loud, so wondered if a way to turn it up more.
thanx
conty
If your using your own ringtones maybe its the file quality thats the prob, for eg with MP3's you will prob need to increase DB using a program like audacity thatll
make it a little louder
also if you turn the volume up to full you will note (if vibrate is on) that first few seconds are really low so keep volume on one less than MAX -
