Philips Camcoder Gives Funny Colors On SX1
3 replies · 2,567 views · Started 04 November 2004
Dear All ,
I tried Philips Platform4 CamCoder 3.7.5 Pro and i encountered the following issues :
1 - The applet fires too slow, is it incompatiable with sx1 ?
2 - After encoding, file plays in funny colors, mostly green mosaic
3 - Encoded file despite stated based on Mpeg4 Codec fails to play on pc media player (or any other)
Now i ran to those issues while trying to solve the problem, everybody states that Eti Camcoder is the next leading device, but what is its URL ? try finding it on google and you will end up trash.
Even Camcoder Pro itself cant be found on Philips site ! try running a search on its name within philips domain and you will end up looking at cathode tubes.
So can anybody help me with these issues ? if so please note what um missing and state official websites if possiable.
Best Regards
GhostDog wrote:You can find the latest version in the shop,i don't know if it will work with the SX1: http://www.handango.com/ampp/store/PlatformProductDetail.jsp?siteId=1208&jid=8F4C32X523B526F95299E214CXBDDD75&platformId=4&productType=2&productId=127583&sectionId=0&catalog=20&topSectionId=-1
Would you rather post me the ecommerce urls ? cant seam to find em in shops near me, besides i want to know the official websites for support. Btw , are such symptoms discussed common to SX1 users ?
Best Regards
Sorry,don't know them.
There are some problems with third party applications because the Series 60 version used on the SX1 is a bit modified by Siemens although i don't think i've encountered this one but i wouldn't count my self as a good source of information on this subject since i don't own an SX1.You might have more luck searching the forums.
