Mp3 player
4 replies · 1,583 views · Started 04 November 2004
I am not sure I fully understand the problem you are describing - are you saying that when a call comes in & the built in MP3 player is running, it pauses the track but then doesnt resume when the call ends, or that the MP3 player app shuts down ?
I cant say I have tested this scenario, however, I can advise that I have been unable to get either the Viking Informatics or Lonely Cat Games players to work properly on the Sendo X. Although both applications run (note: the latter wont if you have a memory card installed - which seems bizarre), neither app is able to decode MP3 tracks correctly. From other posts this looks like it could be caused by the way the Sendo X audio driver has been written/implemented, although we would need someone from Sendo to confirm this.
No the mp3 appl its no shutdown but song after end call still in pause and i like if automatic after end call unpause ....how ???
lout wrote:No the mp3 appl its no shutdown but song after end call still in pause and i like if automatic after end call unpause ....how ???
That is correct, the MP3 player will go into pause mode if receiving an incoming call. Simply, re-enter the application (which doesn't close) by pressing and holding the menu button and select the MP3 player and press the centre select button to continue.
You may find other 3rd party mp3 apps which don't do this but i personally prefer the existing apps set-up.
