Hi All,
I have Nokai N-gage model.
I am facing problem when I tried to connect to Internet using GPRS.
The service provider send me settings to access the INternet which works on Nokia 3510i but N-gage gives me error message as "App. Closed Browser".
Please help me out .
Thanks,
Sudhir Parab.
A full reformat (*#7370#) might clear things up (note that all settings, contacts, messages, etc., will be gone - the phone will be as it was when you first got it, more or less).
If a reformat and getting the settings again does not clear that error, then the next step is probably a trip to the nearest Nokia service center (but I suspect that it is not needed for this problem).
N/A wrote:A full reformat (*#7370#) might clear things up (note that all settings, contacts, messages, etc., will be gone - the phone will be as it was when you first got it, more or less).If a reformat and getting the settings again does not clear that error, then the next step is probably a trip to the nearest Nokia service center (but I suspect that it is not needed for this problem).
I do the steps which you told to me and It works fine now thanks.
Once again thanks,
Sudhir.
I got some problem with my n-gage...i couldn;t do anything with my n-gage...!I tried reformat my phone(*#7370#) but it came out nothing happen....everything still there....simply means it haven't been reformatted...den i tried using the green key+3+*....but it din work....any solutions?if can email to me at [email][email protected][/email]
thanx....ur help is real needed
