Think Outside keyboard on A-925
3 replies · 1,864 views · Started 04 November 2004
Hi
Seems i just made the mistake of my life, i want to use a keyboard to my Motorola A-925 and i bought the Think Outside Stoway Wirless Keyboard. Now is there any way to get it to work? (The manual sux)
I had no problem geting the latest driver inside my phone and installing it, but it doesnt show up on my bluetooth list, i cant find it from my phone.
plz plz, is anybody using a keyboard to there A-925 and is there a way to get this keyboard working?
/Best Regards
/Peder Nakazul Tjernberg
I don't know, I only know the A925 is not supported officially. Have you mailed ThinkOutside already?
All I can advise is: have a little patience. Not everyone checks in here every hour or so...
I know, sorry, im just kind of desperate, i been longing for a keyboard to use. I have mailed the support, but supports take a long time to reply and mostly dont know anything.
All i know of this phone is self expermenting, and that sux, but i dont care that much about it (Maybe some what frustrating).... but in this keyboard i care ... it didnt come for free ither. Typical to rush away and buy somthing just because i stop to think ... wish P910 was not that expensive and could get easy config with 3G company Three. I love this Telephone vs Computer thing but as you said ... Motorola A-92x support is .... where? =)
Okay a frustrated me has been trying diffrent aproaches throu Bluetooth connection (IR doesnt work at all)
1. Telephone master and keyboards slave: The keyboard shows up and im prompted to type a password (12345) i tryed and then it seeks for a while only to inform me that the connection is not found.
2. Keyboard master and Phone slave: Well this is really wierd (in my oppinion) .. I can search the keyboard and add it so my list in bluetooth devices, then turn on the software that came with the keyboard and the keyboard will start and i kan type messages .... for 3 secs, then it dies for 5sec ... and it comes back for 3:sec and...it ... wee you se the point.
I have searched internet but found no answer ... somehow if i get the picture right, the keyboard is still having some software devloped to it so .... if nobody have another software tip (sis file) i guess im out in the cold...again (Dont i just hate that). What should be rememberd is that i have a small brain so i hope i have som possibility to get it to work still.
Well thats it for now, now i have typed some of my disepointment down (dam it feels a little better) im open for suggestions.
