mmc write protected on 6230
11 replies · 9,677 views · Started 04 November 2004
I'm really sorry if this is a stupid question to be asking I'm new to this. Just got a card reader for the mmc in my 6230, it's the standard 32mb mmc and when I try to delete stuff on the pc it says it's write protected and if I try to put stuff on the card it says the same, anyone know what I can do. Thanks in advance and I do apologise if this is a really annoying popular thread.
reckless-zed wrote:I'm really sorry if this is a stupid question to be asking I'm new to this. Just got a card reader for the mmc in my 6230, it's the standard 32mb mmc and when I try to delete stuff on the pc it says it's write protected and if I try to put stuff on the card it says the same, anyone know what I can do. Thanks in advance and I do apologise if this is a really annoying popular thread.
Yeah, Ive got the same problem. Its sucks huh - especially as I just bought a 1gb card to use in the phone 😞
Hope someone can help!
terry wrote:Yeah, Ive got the same problem. Its sucks huh - especially as I just bought a 1gb card to use in the phone 😞
i just solved the problem by uninstalling the f*cked drivers that came along with the mmc card reader/writer (emagic 9-1) and used plain win xp drivers for the usb mass storage , works like a dream now
now using Twinmos 512mb MMC with the 6230
// zipp
The One And Only Solution To This Problem!!!!!!
I Don't Know How It Came To Me But It Is Very Simple
Just Cover The Last Pin That Is Closer To The Cut Edge Of The Card With Some Clear Tape And Voila!! The Card Is Not Write Protected Anymore And Works Just Fine!! I Tried It In A Card Reader And In A Nokia 6230!!!
Hope That Solved Everyone's Problem
Have Fun With Your Nokia
erm... I have the same poblem but the above suggestion does seem like cack! lol
I tried ti to be sure and it don't work on mine!
lol
Any other ideas?
zipp69 wrote:i just solved the problem by uninstalling the f*cked drivers that came along with the mmc card reader/writer (emagic 9-1) and used plain win xp drivers for the usb mass storage , works like a dream now
// zipp
I am currently using the WinXP drivers and I encounter the same problems. I can only copy certain files and most of the time, unable to copy due to this write protection thing.
ot it:
Under Windows XP SP2 you have to set a new entry
HKEY_LOCAL_MACHINE\ System\ CurrentControlSet\ Control\ StorageDevicePolicies
with name WriteProtect
Typ: DWord-value
value 0 = write protection deactivated
value 1 = write protection activated
How can I make this solution with Win2000???
I cant find the:
with regedit in win2000
Please help me out.
N/A wrote:If the registry key/value isn't there, you can create it/them.
Thats what Im trying to do but I dont know in which folder?
