Hi guys, do you know if exist a GPS cable module for Nokia 6600?
Cable modules are usually less expensive than bluetooth ones... that's why I'm asking it!
I would like to use it with the Tom Tom mobile navigational software.
OldMan (Italy)
OldMan (Italy)
Unfortunately you would then not be able to connect it to the 6600 as it does not have a similar connector, it doesn't even have a Pop-Port!
I have just taken the plunge and got a TomTom GPS Receiver off Ebay for �100 and it's great. You can get cheaper one's, just remember you need one with the same GPS module as the TomTom one.
Some of these work with TomTom :
http://www.pdamods.com/products.asp?cat=16
And I think this is what the GPS Module has to be : SiRF Star IIe/LP
Go on, take the plunge you won't be disappointed!
Ian
Thanks Coolice, very kind of you...
I will go and give it a look!
Best Regards
Luca
