Peculiar, but I cannot send a reply to one particular person who is in my contacts list. Replying to everyone else is OK, except this one. Anyone have this problem and anyone have a solution?
Cannot reply to as particular mail sender
Hard to say without details. What's the email address? What happens (what error messages, if any)?
You can also simply delete that person from Contacts and re-enter. Does it help?
SAME PROBLEM HERE; i dont know if i cant reply to one of my contacts list, i only know that if i am going to reply 1 sms from my buddy i cant, it just says "failed to send the message" and i only can reply him makin a new message....
I tried changing message center number and the other options but nothing changes..
any solution??
The original poster had email problems, not SMS (which is a different thing).
For SMS, it is usually the "Reply via same ctr." setting, which in 99.9999% of cases should be set to "No", that causes problems (menu > Messaging > Options > Settings > Text message). And verify that the "Msg. centre in use" is either "SIM msg. centre" or the correct number for your own operator/carrier (who issued the SIM card).
That may be happening if he is sending it from a website or free sms service and not from his cellphone. Therefore the reply to address is messed up and would not be correct, so msg sending would fail.
