Hello!
I have searched the forum for an answer of my question but have not found any solution so far.
The problem I have is that sometimes when I try to install programs on my N6600 it just shows "Installing" and then I'm back in FExplorer, no message, nothing.
This problem is with many programs, but not all. For example I have tried to install Appman, HandyFile and HandySafe without success and Doom, GoBoy, Triz and ZipMan with success tonight.
Please help. 😊
BR
Lelle
Which version u r using? and do u install the application with P.C Suite.
I am using version 4.09.1 and I dont use PC-suite,
Try Installation via P.C Suite
If u don't have the latest then download from Nokia.com
If u still face the same problem then u need Format.
Wont I need BlueTooth to use P.C Suite?
Tried to get the phone working with BT on this computer earlier this week but couldnt get it working so I thought about a format but never did. Do you know what can be the reason for this problem? The solution is the most important, but it can be good to know why it has happened too 😊
Btw, really good forum. I have found answers of many questions here. 😊
BR
Lelle
Hello again.
I just tried the *#7370# format thing and I could now install Appman. So I hope it works.
