i have a nokia 6600 v4.09.1, I had installed a game Talon.. it was working fine till yest when suddenly after a reboot.. the icon was no longer present in the menu. use seleq. exploring my mmc card( 32 MB orginal) i found the games in app but the contents of talon directory show 4 garbled files of sikes few kbs to 503 mb . I am not able to deleted the directory or files.
A same problem on my friend's phone is that he tranfered a SIS file which is in his inbox. after he was thru with the install he is not able to delete it .. error says " General : Already in use "
Any help wil be apperciated
System Wizard
I've had similar problems when playing around with installation files. Aare there any odd processes running if you press and hold down you menu (blue arrows) button? If there is, you can try to stop it using a memory manager (Switcher etc.)
I can't see how an app like FExplorer wouldn't delete the files and folders, but otherwise using a memory card reader on a PC with a decent OS should do it...
As for your friends unit, you have to search through your messages folder for the offending files. Again FExplorer has sorted me out a few times in this situation, it great for searching and deleting these sorts of things. It's been covered quite comprehensivley in a thread on here b4...
Good luck...
M.
Hi dj_meerkat,
I have the same problem as vswizard's friend.. How do I delete a .sis file in my inbox?
I've used FExplorer to search the file in c:/system/mail.. however how do i know which message is it? coz therer are only files in binary names under this directory..
any help appreciated thanks..
chasonv wrote:Hi dj_meerkat,I have the same problem as vswizard's friend.. How do I delete a .sis file in my inbox?
I am using a Nokia 3650 and experienced the similar problem as you guys. i.e. General: Already in Use
I used a Notepad to view the index file located in c:/system/mail . I then erased some text which I believed is linked to the corrupted file. However, I guess I did not erase it correctly cause when I put my MMC card back into the phone, and opened the Messaging program, there is not even one icon in it.
Nokia should have written a program to de-cypher those binary stuff in a user-friendly-pc form.
Tee Horng Hean
www.freesoftware.com.my
teehornghean wrote:I am using a Nokia 3650 and experienced the similar problem as you guys. i.e. General: Already in Use
I used a Notepad to view the index file located in c:/system/mail . I then erased some text which I believed is linked to the corrupted file. However, I guess I did not erase it correctly cause when I put my MMC card back into the phone, and opened the Messaging program, there is not even one icon in it.Nokia should have written a program to de-cypher those binary stuff in a user-friendly-pc form.
Tee Horng Hean
I was searching the web and I do not know if this helps. Goto http://www.zedge.no/phpbb/viewtopic.php?t=269 to read the message there.
Basically this guy just tells you to: -
1 Go to http://www.aivanet.com/en/
2 Download 50kb file explorers for your phone.
3 upload the file explorer to your phone
4 launch it, and go: C:\System\Mail\ to delete your file
Hope that helps
Tee Horng Hean
