Nokia 6620 in Nokia 6600's look
6 replies · 3,069 views · Started 07 November 2004
I was thinking of buying nokia 6620, but i have nokia 6600 now..I really like the cover of my 6600 so i was wondering is it possible to have 6620 in nokia 6600's look which means is it possible to have 6600 faceplate on 6620 plz help..........
do you know where can I find a faceplate for 6620 that looks like faceplate of 6600
Now I'm intrigued...!!!
I understand the 6620 is the US version of the 6600 from what I've read here, but I wasn't aware they looked different...and it sounds like it's more than just a colour scheme thing (if the cases aren't interchangeable)...
Has anyone got a pic by any chance? How much difference is there between these two units? I'm kinda glad I qualify for the 6600 if they look that bad...!!!
M.
6620 new features over 6600:
- EDGE technology
- stereo
- newer symbian OS
- larger internal memory(12 mb)
- brighter screen(? not sure)
- faster system (so i heard, not sure)
maby some more, cant remember off the top of my head...
BTW, i could of sworn the 6620 and 6600 had the same sized casing....
neuro wrote:- newer symbian OS
Same Symbian OS (7.0s), but newer Series 60 (2.1 vs. 2.0).
khota wrote:I was thinking of buying nokia 6620, but i have nokia 6600 now..I really like the cover of my 6600 so i was wondering is it possible to have 6620 in nokia 6600's look which means is it possible to have 6600 faceplate on 6620 plz help..........
the casing/housing/faceplate of 6620 is different from 6600 especially at the bottom part.. if you use a faceplate of 6600 to 6620 there will ba an open portion on the bottom..
