Guys plz help
2 replies · 1,509 views · Started 07 November 2004
Wirelessly posted (Mozilla/4.1 (compatible; MSIE 5.0; Symbian OS; Nokia 7610;451) Opera 6.20 [en])
HoW can i save my contact to the memory card...Mine is
7610 thanks
I Don't think you can
Other way is u can make back up using Extra-> Memory-> Option-> Create Phone Memory Backup.
or trsafer to computer using 3rd party paid application.
The Contacts app keeps the contacts only in phone memory. There are apps you can use to export the contacts to a file to memory card, though. E.g., Contacts Manager: http://my-symbian.com/7650/applications/applications.php?fldAuto=392&faq=2
If you use the Memory app and its backup feature, it will also store contacts (with the settings, messages, etc.) in a backup file on the memory card (which can then be restored with the same Memory app, if needed).
