Guys,
I've noticed that when I receive an incoming call, the ringtone volume always begins low and then about 5 seconds later increases to its selected level. Is this normal? It seems that there is no option to do anything about it. I have to say I find it quite annoying and I see little point in it.
Cheers!
not sure but i think your find thats the vibration, turn it off and it will be loud from the begining
yup.. i asked the nokia service staff.. except for switching off the vibration, there's nothing tt can remedy it.. anyone got any ideas to override it??
this is been discussed many times before on the forum, but again you just keep the volume one less than full with vibrating on and its fine
abba wrote:this is been discussed many times before on the forum, but again you just keep the volume one less than full with vibrating on and its fine
the other posts didnt give any solutions to it although it has been discussed.. anyway i found out that with the new firmware V 4.0437.4ch 15-09-04 RH-51, it is fixed..
