Does anyone know the pin assignments on the 6620? I know they switch based on what enhancement is connected to the phone. How does the phone tell the difference between a mono and stereo headset? I know by shorting pins 1 & 2 (going right from the power connector) the phone thinks there is a headset attached, what to do to make it think its a stereo headset attached?
Pop Port Pin Assignment - Help
Nokia knows, but has not published any Pop-Port interface specifications as far as I know.
No one has any experience playing with the pop port output? Or understand the engineering behind the difference between the data, stereo and mono cables?
Wumpscut223 wrote:No one has any experience playing with the pop port output? Or understand the engineering behind the difference between the data, stereo and mono cables?
http://pinouts.ru/data/pin_nokia_pop.shtml
If you figure out how to get Stereo output, hook up with the info!
