Nokia 3660 no start
7 replies · 2,645 views · Started 07 November 2004
I have a Nokia 3660 ... this afternoon i got my mobile out of my pocket to find it was switch ed off. I tried switching it back only to find it wouldn't go on at all. it just decided to remain switched off permanently. Itried charging it thinking that it may be low on charge ... nothing .. it won't even charge. I tried looking in these fora for a solution but nothing seems to work!!!!!!
Please helpppppppppppppppppp!!! I can't spend a day without a mobile!!!!
JP
Doesn't even the light go on? My 3660 often starts but the only thing I see is 'Nokia'. Then it helps if you just take out your MMC and try again.
Mac Fly wrote:Doesn't even the light go on? My 3660 often starts but the only thing I see is 'Nokia'. Then it helps if you just take out your MMC and try again.
Nothing at all happens .....😞 .... not even when i put the charger in!!!!!!!
The MMC is out, i tried safe mode start .... i tried format ... nothing happens!!!!!!! JUST A BLANK SWTCHED OFF SCREEEN!!!!
GRRRRRRRRRRRRRRRRRRRRRRRRRRRR
JP
hi! I'm meg... I think we have the same problem.. I think that 7 or 8 of 3660 owners have this same problem... I think we need to RECALL this N3660 to Nokia company to give us at least a discount maybe?... for the repair or I think they should stop producing n3660 beacause I think it is the OS of n3660 has a problem that once you put many application, it just shutdown and you can never turn it on again
I don't think it is a Bug in the OS. Mine works very good it just has not enough RAM. If you let too many apps launch on startup it won't work right. This is your fault and is the same with a PC.
Mac Fly wrote:I don't think it is a Bug in the OS. Mine works very good it just has not enough RAM. If you let too many apps launch on startup it won't work right. This is your fault and is the same with a PC.
Check if your phone is still under manufacturer waranty at
http://www.nokiausa.com/support/warranty/warrantyVerification/1,1965,,00.html
enter your IMEI and see if you qualify for free repair
PS. this site is for US, you might need to find localization for your country if you are not in US
