Where is the bet value for money to find MMS RS cards in the UK?
I think www.ebuyer.co.uk are pretty matched with www.mobilefun.co.uk.
Better brand of card though I think on ebuyer.
Cheers,
Nyx.
www.expansys.co.uk are quite cheap
Hi jayteas.
I got an ATP 512 mb RS-MMC from eBay back in September for �65 (inc postage).
Prices on mobilefun and expanses at the time were approx �95, although they seem to have come down considerably since then,
eg. a 512mb on expanses is �62 at the moment (inc. postage).
However so have the prices on eBay. I saw a 512mb one for about �40 about a month ago.
Whatever you decide, all I would say is be cautious over possible compatibility issues with certain makes - as this does happen. Look at the reviews to see if people have had any problems with the make that you are thinking of buying. I know several issues with Kingmax for example, when using them in 6600 and 7610 handsets.
Hope this helps.
I bought one of these..
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=42408&item=6338749238&rd=1
off this chap a couple of weeks ago. �39.95 including deliivery. I doubt you will find any cheaper than them at the moment.
Oops, wrong link - is not for the reduced size MMC.
This is the one I bought...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=3848243841
at �39.95, but he has now upped the price to �42.95 as seen here...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=3851707182
Still pretty cheap though, and works just fine in both my 7610, & my camera (with the extender adaptor included).
