Nokia 9500 and gotomypc
7 replies · 4,990 views · Started 08 November 2004
I am interested in the Nokia 9500 as I have not been happy with a pda since the psion series 3mx. I currently have a Treo 600 and its very buggy. My question is will I be able to access gotomypc with the symbian platform? Also will the 9500 perform as a wireless modem which the Treo does do well
I can't answer your first question. But the answer to your second question is: Yes, you can use the 9500 as a wireless modem
goMyPlace is an Open Source alternative to PCAnywhere/GoToMyPC applications All source code is released under GPL. It includes client and server side sources. The application is specifically crafted for using with cell phones.
The application allows to access file system on PC at home/office from regular cellphone, PDA or just another PC
System requirements:
- PC can be NATed and firewalled. Linix/OSX/Win32 with Java 1.4 or better (Sun JRE) installed.
- cellphone, PDA or any other Internet enabled device with regular browser allowing to see HTML files. no JS/Java/.NET support is required.
Features list
- Open source (GPL)
- file browsing
- access to command shell (MSDOS in Win32 and bash in Mac/Linux)
- can be accessed from any browser including text only lynx
- does not require .NET/Java on the client side
- works in firewalled and NATed environments (use any of the ports 21, 80, 81, 443 to connect to the proxy)
- does not require to "punch" NAT
- does no use UPnP to make holes in NAT exposing your network
- daemon running on remote PC never accepts incoming connections, but instead uses "dial back" scheme
- three levels of access to the files - public (Universe), friends, private
- can run in standalone HTTP server mode
- HTTP tunnel to other devices in LAN (not fully supported yet)
- end-to-end encryption (not fully supported yet)
see http://www.goMyPlace.com for installation instructions
see more on SourceForge http://larytet.sourceforge.net/goMyPlace.shtml
and Wikipedia
http://en.wikipedia.org/wiki/GoMyPlace
zyrkael wrote:I am interested in the Nokia 9500 as I have not been happy with a pda since the psion series 3mx. I currently have a Treo 600 and its very buggy. My question is will I be able to access gotomypc with the symbian platform? Also will the 9500 perform as a wireless modem which the Treo does do well
Gotomypc will not work on 9500. I have 9500 and unfortunately it only works with the pocket pc application and not symbian. Its a real pity.
Nilesh
