256/512MB RS-MMC on 6260?
7 replies · 2,871 views · Started 08 November 2004
Nokia is selling "only" 64MB RS-MMC card as accessory for 6260. Have anybody tried the 256 or 512MB RS-MMC vard on 6260. Do they work?
NorthernLight wrote:Nokia is selling "only" 64MB RS-MMC card as accessory for 6260. Have anybody tried the 256 or 512MB RS-MMC vard on 6260. Do they work?
I�m using the 6260 with an Transcend 512mb RS-MMC, works like a charm for me... I even use the same card for a Casio Elixim QV-R41 Digital Camera... 😊
Kurzweilfreak wrote:I�m using the 6260 with an Transcend 512mb RS-MMC, works like a charm for me... I even use the same card for a Casio Elixim QV-R41 Digital Camera... 😊
Same here. Comes with an adapter so it'll fit in normal card readers too... I got it for $75 shipped. Great deal considering the amount of memory you get.
i used 512mb rs mmc ATP on my 6260 and it worked 100% no problems with 200mb of apps and various stuff
i've just bought a new 256mb rs-mmc to replace the small 32mb rs-mmc for Nokia 6260.. i tried to copy all the files/folders using a card reader, but the nokia-supplied rs-mmc won't open.. what's the problem? is there any other method of transferring all the files/folders/programs from the 32mb rs-mmc to the 256 mb rs-mmc? i don't want to mess with the files.. thanks...
mangkuk wrote:i've just bought a new 256mb rs-mmc to replace the small 32mb rs-mmc for Nokia 6260.. i tried to copy all the files/folders using a card reader, but the nokia-supplied rs-mmc won't open.. what's the problem? is there any other method of transferring all the files/folders/programs from the 32mb rs-mmc to the 256 mb rs-mmc? i don't want to mess with the files.. thanks...
Try This
http://www.allaboutsymbian.com/forum//forum/thread/30744/
sounds like you have set a password on the mmc. remove the mmc password using your phone, then the card reader/pc should see it with no problems.
then you can perform the copy as per vicky's instructions from the above link.
dan
