new user, quick question, please read
3 replies · 2,726 views · Started 08 November 2004
Hi
I'm just about to be given a 9210, and currently know nothing about them. Think the keyboard and sturdy design of it may out perform my xda in several areas anyway...
At the moment I can simply connect my xda to my desktop computer and use active sync to effectively put the xda on the internet for using msn messager etc...
Can this be done with the communicator??, sure it can somehow. Also is there a free msn messenger client?
using the communicator on msn while i work away on my computer is a dream to me 😊
many thanks.
errrm think i need to walk before running 😊
just got the phone and its a 9210 pretty cool but has some problems. i'm hoping they are common problems that you have all seen before.
i go to the word processor app and if i try to quickly type QWERTY i get the q followed by a load of spaces?? the keys work fine in the contacts etc...
help please
i have just discovered that it is the W key that is causing the problems. in write new message or the word thing it messes up. every key pressed after the W shows up as a space. when i save the message the preview looks ok (with all the characters present) but then when i open it they are all missing again??
the w key works fine else where like writing a note etc....
pleeeease advise?
reset fone? :icon13:
i dunno.
make sure you have backups; especially contacts and foreign apps
