saved the message on MMC???
2 replies · 3,011 views · Started 08 November 2004
I would like to save the message on the MMC. I have already downloaded the MSVDRIVEE but doesn't work! Can you help me??? :con?
I have 256MB MMC and firmware version 12
PML86 wrote:I would like to save the message on the MMC. I have already downloaded the MSVDRIVEE but doesn't work! Can you help me??? :con?
it is very easy...u first need to download it to your mobile then u install it on the MMC and after that u just need to run it...a white screen will appear and stay a while so don't panic it's normal, it is just creating a mail folder on the MMC.
if u have an application to explore folders on your mobile (like SELEQ), u can check if a folder is created under the name of mail (this is the root E:\SYSTEM)
I hope that I answered u the way it works 😃
